This command configures the advertising status of the power available TLV on CDP ports.
advertise | Specifies to send the TLV to neighbors. |
no-advertise | Specifies not to send the TLV to neighbors. |
port_list | Port list separated by a comma or - . |
No-advertise.
This command is for PoE switches.
The following example advertises the Power Available TLV on port 1:
configure cdp power-available advertise ports 1
configure cdp power-available no-advertise ports 1
This command was first available in ExtremeXOS 21.1.
